Spacers for RS engine mounts, or not?
I was referring to the sag in my original mounts, which I thought still had loads of life left in them, but maybe they're on the way out.
I'll get myself a complete set of bolts and washers from Porscha, in case the others I sourced are below par strength-wise. Many thanks for all the info
BTW Now that you've got rid of the sag, check the tail pipe for bumper clearance and adjust if necessary.
Technical Guru
Slightly different but possibly relevant (?), when Porsche installed the 964RS engine mounts on the 993TT as part of the X73 option, they increased the diameter of the washers from 34mm to 45.5mm and increased the bolts to 125mm.
Technical Guru
Porsche fitted the RS mounts on a turbo? First Ive heard of it. X73 is 20mm ROW lowered suspension. Diameter, not width I think. 110mm bolts work, 125mm would work too!
Now that this thread has wonderfully turned up the experts on mounts, what would you guess-timate would be the milage that you might count on replacing them?
Mine look a a tad saggy, and they are the originals: 80k miles, no hard or wild driving.
Thanks.
Thanks.
It was a mid-model/year(MY97) upgrade?
"Whenever replacing one or both engine mounts on the above-mentioned
vehicles, both engine mounts should be updated to a new type engine
mount, (part number, 964 375 043 81) if not already equipped."
Here's the TSB.
Here's the TSB.
Technical Guru
If in doubt, replace. The cost of your originals failing will outweigh the cost of what is a relatively easy (and very satisfying) upgrade. I went with RS' bug the Wevos look great too.
