Mounting ABS/PDAS ECU Upside Down
I have heard that this is a good idea to prevent moisture corroding the plug/pins. I have searched but not found a method for doing this. Does anyone know of a post or can take pictures of what you did to mount the unit upside down in the trunk.
I just had to get a pin replaced (hopefully the repair worked) and do not want this to happen again.
Thanks.
Thanks.
I have heard that this is a good idea to prevent moisture corroding the plug/pins. I have searched but not found a method for doing this. Does anyone know of a post or can take pictures of what you did to mount the unit upside down in the trunk. I just had to get a pin replaced (hopefully the repair worked) and do not want this to happen again. Thanks.
