964 Forum 1989-1994
SUDDEN POOR EXHAUST EMISSIONS TEST- ?WHY
Old 04-08-2014, 11:50 AM
964enthus
964enthus's Avatar
Default SUDDEN POOR EXHAUST EMISSIONS TEST- ?WHY
Hi
over the last 7 years ,i had always had excellent test results :
HC 4 to 12
Co 0.008 to 0.132
Sudenly ,this year :
HC 130
CO 3.23 !! (nb 3.5 is the limit )
I thought the o2 sensor might be disconnected :apparently not
i tested the O2 sensor with a voltmeter ,the readings are ok
the car behaves just the same as before ,no smoke at the exhaust ,no stalling ,acceleration the same ,no misfire....
i am puzzled ,because if CO increases just a bit ,the car will not pass the test next year
Would you have any ideas about where this could originate from / ? what I should look at ?
Already had similar issue ?
All suggestions welcome
peter
Old 04-08-2014, 12:05 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Peter,
One needs a LOT more detailed information in order to offer anything constructive.
This would include:
Total miles on engine
Mileage on distributor caps, rotors, plugs, ignition wires
Air cleaner condition & mileage
Oil consumption
Oxysensor mileage
Old 04-08-2014, 12:11 PM
964enthus
964enthus's Avatar
Dear Steve
thanks for your questions
mileage is 68 000 miles
all equipment is original
ALL BUT PLUGS ORIGINAL /PLUGS 500 MILES
CLEAN 3000 MILES
Oil consumption
HARDLY ANY /NB I ONCE HAD A CLOUD OF SMOKE AFTER A 2 months stay in the garage /PROBABLY SLIGHT OVERFILL / DID NOT REHAPPEN AFTER REMOVING HALF LITER OF OIL
Oxysensor mileage
ORIGINAL ,VOLTAGE TEST SHOWS OK
peter
Old 04-08-2014, 01:45 PM
hamah
hamah's Avatar
Could be an anomaly in the test or equipment itself. Did you ask for a 2nd test on different equipment?
Old 04-08-2014, 02:02 PM
964enthus
964enthus's Avatar
yes in fact the first test was at the mot itself
3 weeks ago
i thought it was simply a problem of disconnected o2 sensor
so ,i checked the connection and had another test at another garage today
Old 04-08-2014, 08:04 PM
Originally Posted by 964enthus
Dear Steve
CLEAN 3000 MILES
Oil consumption
Oxysensor mileage
peter
Hi Peter,
Thank you kindly for the data; that really helps.
At 68K, everything is long past due for replacement as those items determine ignition quality and combustion. I would install new caps, rotors, plug wires, and perhaps the oxysensor, depending on how fast its cycling. If you can read the values on the DVM, its toast. A fresh one cycles so quickly that the lambda numbers are almost unreadable.
Old 04-08-2014, 11:08 PM
lateforlunch
lateforlunch's Avatar
^all great advice. In addition I think you'd be wise to check for vacuum leaks and/or a leaky fuel pressure regulator. Dumping un metered fuel into the intake will throw off your CO just as easy.
Old 04-08-2014, 11:15 PM
swftiii
swftiii's Avatar
When was the last oil change? I had an issue once when the car had sat for a while and the oil was pushing a year. Changed the oil and put a 100 or so miles on the car and passed the next try.
Good luck!
Old 04-09-2014, 02:50 AM
axl911
axl911's Avatar
Your HC also jumped 10x to 130! You're running rich! Is this at idle or at load?
Could be that you have a vacuum leak.
Old 04-09-2014, 07:15 AM
964enthus
964enthus's Avatar
many thanks for all your comments and suggestions
oil change : was done last year (only 500 miles)
idle or at load test ? at load :2500 rpm
such a sudden change seems to indicate an excessively rich mixture
I'll try first : vacuum leaks and/or a leaky fuel pressure regulator(my job for tomorrow !)
Am I right to suppose that running the engine with that sort of emissions WILL NOT DAMAGE THE CAT ?
Quick Reply: SUDDEN POOR EXHAUST EMISSIONS TEST- ?WHY
