Removing the gear shift knob insert
I need to replace the gear shift **** insert on my 964. The one with the 5 speed shift pattern in it. I know that it is just pryed out but is there a preferred tool to use so as not to damage the leather around the top? Once it is out does the new one just fit with friction or does it have to be glued? If it is glued, what would be used?
Thanks in advance.
Thanks in advance.
