964 Engine Rebuild Questions...Help
Hi All,
I'm needing some help in identifying parts I need to complete my costly rebuild.
Issue: A family member either misshifted or overrevved causing the driverside middle cylinder with no compression. After opening up the engine, I found the piston (chipped), cylinder (cracked), exhaust valve (bent), rocker arm (broken)
I have the rocker arm, and exhaust valve already, but find it difficult to find the correct cylinder and piston.
On the cylinder has: 95ZN6 ++++ A2 W5 what does this mean?
And what markings are there on the piston?
Here's some pictures for the piston and cylinder....
Damanged piston and cylinder
http://i42.photobucket.com/albums/e3...ps943556d1.jpg
Good piston and cylinder
http://s42.photobucket.com/user/LJ_D...fc7bb.jpg.html
