Stuck on rear PSS10 installation - help! PROBLEM SOLVED
So I have the front PSS10s in but on the rears I want to torque the rear piston bolt before I install it due to the tight space back there (at the front of the engine). On the fronts the bolt required an allen on the inside of a socket. The allen holds the piston as the socket tightens the nut. However on the rears there is no allen- the piston is simply threaded. No allen, no flat spot anywhere on that shaft to hold it therefore when tightening the nut on the piston, the piston spins. How do I torque this nut?! My only guess is that it is meant to be torqued only after all the car's weight is on the shock which means I 'll need to drop the car off the stands and torque in that tight space. I don't want to go through all that to find out I'm wrong. Please help me if you' ve tackled this before. Thanks.
Here's a pic of the top of the coil over showing the flat head (no allen) and the nut.
Attachment 811401
Attachment 811401
[QUOTE=perelet;11178323]I have PSS9 and there's hex socket opening in rears:
The PSSs have apparently "evolved" -obviously my thinking needs to evolve too!
All over the literature Bilstein says not to use an impact wrench- these are too $ to mess up so I'm avoiding using it.
I figured it out. I used channel locks (padded on the teeth of course) just below the hats in an area that wasn't part of the shaft/piston stroke. The nut only needed 47 ft/lbs of torque so it didn't take much force to hold it.
Unlike the frontt coilovers it is key to torque the nut before installation otherwise, once installed, one would be unable to access that spot with the channel locks.
Email your pics to Billstein USA - they respond pretty quick. I won't be driving those until you sort this out.
Here's real pss10 rear top pic:
Thanks Perlet. What year is your car? As I understand it there are two models of the Pss10 those up to 90 and those after. My car is the latter and the rears are Bilstein #F4-VM3-D266-H2 which they spec for my 92. They fit fine...I'm now putting her back together. Let me know if you're not convinced.Thanks.
Oh boy.
Email Bilstein USA and attach your pic, they do not charge for emails and know years/part numbers better.
Just double check if yours are not made by BillyChtein Ltd China.
Ps. I also presume that you cleaned up that funny looking grease from tops - maybe there's hex under it? Also torquing greasy thread is not good idea channel locks or not.
How did everything turnout and how do you like the strut choice? Are they too stiff for mostly Street? I have original 1994 C4 Turbo look setup, which I beleive is same as Turbo suspension. Top of front mounts are painted Yellow? Don't know what shocks I have
The PSS10 suspension was incredible- really transformed the car. I used it for daily driving and autocross.
