ABS wiring diagram needed
In amongst thesee I imagine
Apologies I havent ploughed through it to check
http://www.cannell.co.uk/_manuals/po..._electrics.pdf
Ok looks like I've found something, with the wiring diagram and abs plug pin out I did an ohm test for the sensors at the abs plug with LF 1021 ohm, RF 1003 ohm, LR 1008ohm and RR 0.04 ohm
Unplugged the sensor and it reads 1013 ohm when testing it on its own, did further tests on the wiring and with the abs plug disconnected in the front I still get 0.04 ohm across the terminals with no abs sensor connected.
This points to the 2 wires touching each other in the loom somewhere, any hints where the most likely place is to start?
There are two connectors on each rear wheel. One on the trailing arm and one on the body (follow the wire back) . Try disconnecting that plug also and retesting. Failing that, inspect anywhere the cable passes through a bulkhead.
