964 Forum 1989-1994
Offset help please!
Old Feb 21, 2014 | 05:16 AM
mf_rsr's Avatar
mf_rsr
Default Offset help please!
There seems to be a lot of experienced wheel thinkers here and J, ET, PCD all bamboozle me, therefore quick question to the wise:
Will 8.5J ET 56 front and 10J ET 65 Rear fit?
Would I need spacers etc?
Planning on running 225 and 265 section tyres...
Cheers RL
Old Feb 21, 2014 | 05:43 AM
BLACK-BETTY's Avatar
BLACK-BETTY
Hi Mark!
Yup fronts are good but may need a 5mm spacer at most, the rears will want to be around 47 so a circa 18mm spacer would be necessary. If the spacer is anything over 5mm I recommend using longer wheel studs for safety.
Tyres sizes are perfect. Any pics?
Old Feb 21, 2014 | 05:50 AM
mf_rsr's Avatar
mf_rsr
Cheers Frank :-)
They're 20 hole BBS GT2s, local seller, and I'm trying to find some more information about these as they are the motorsport design but hopefully more road-useable? Also keen to find out weights etc. Google is coming up fairly blank...
Any one have any info?
Old Feb 21, 2014 | 07:05 AM
BLACK-BETTY
Oooo those sounds nice.
Old Feb 21, 2014 | 04:42 PM
n.dino's Avatar
n.dino
You'll be fine with right spacers. Those are sweet!
Old Feb 21, 2014 | 05:17 PM
STUARTQ's Avatar
STUARTQ
Look like nice wheels!
Old Feb 21, 2014 | 06:49 PM
BHCfarkas's Avatar
BHCfarkas
I would run a 7 - 10mm spacer on the front as I found quite a bit of rubbing on the inside fender liner when I was running 8.5 ET 57
Old Feb 21, 2014 | 07:56 PM
mf_rsr's Avatar
mf_rsr
Still stuck re. more info on these wheels. They are 20 bolt whereas e28 and e88 are 24 bolt...anyone have any knowledge of these at all?!
Old Feb 26, 2014 | 03:31 PM
BHCfarkas's Avatar
BHCfarkas
I'm sorry, but I don't see any pictures or anything regarding the wheels, so hard to say what they are.
Old Mar 5, 2014 | 02:57 PM
schwarz930's Avatar
schwarz930
Instead of starting a new thread can I just ask a wheel fitment question of my own.
Will these suit a NB 964
Front 8x18 ET 52
Rear 10x18 ET 52
Will I need any spacers?
Thanks guys
Jon
Old Mar 5, 2014 | 03:26 PM
BLACK-BETTY
Front 8x18 ET 52
Rear 10x18 ET 52
Yes those will fit fine if you're running a normal ride height and geo.
I would add a 5mm spacer to the rears to fill the arches a tad more.
You'll want 225 and 265 on those wheels. Pictures when done pls.
