964 Forum 1989-1994
Oh no, HVAC issues...
Old 08-18-2014, 10:11 AM
  #46
STUARTQ
STUARTQ's Avatar
Originally Posted by pi5tolpete
For stepper and 12v type servos, RC does provide. Have a look here. No affil
no link
Old 08-18-2014, 12:45 PM
  #47
wwest
wwest's Avatar
Sounds as if it's the small blower that sucks/blows cabin atmosphere over the IAT sensor.
Old 08-18-2014, 04:11 PM
  #48
Henriks 964
Henriks 964's Avatar
Originally Posted by ToreB
The CCU fan runs constantly at ignition on, and up to 20 minutes after ignition off. There is no connection between this fan and the others in the car other than the above.
On all (not the very latest) 964 models, the minimum main blower fan speed is "1", even if the dial is set at 0.
Cheers,
Tore
Tore and Stuartq thanks for the information.
Old 02-20-2016, 01:39 PM
  #49
TYPE911
TYPE911's Avatar
Originally Posted by STUARTQ
no link
Where/what is the link. I am in need on my 964...
Old 05-22-2017, 04:56 PM
  #50
Beezztie
Beezztie's Avatar
The mixing chamber temperature sensor is a NTC for sure, not a thermocouple sensor. However, I am unsure of the NTC value, I expect it to be a normal 12,5kOhm type based on the car schematics information (12,5k @20 degC) and on the other sensors used in the HVAC system.
Cheers,
Tore
I have a broken sensor at the right mixing chamber, taking it out there was no resistor present anymore, only the two wires that held it
Did anyone find out it it is indeed a NTC, and what value?
I found this one:
B57164K0103J000
2904
B25/100 =4300K, R25 =10000Ω, TR =25°C, ∆RR/RR =±5%
@20dgr. Celcius:
Rnom[Ω] 12683ohm
Rmin[Ω] 11949
Rmax[Ω] 13418
https://www.conrad.nl/nl/epcos-b5716...ks-500622.html
That might do the trick?
Seems silly buying a new sensor for approx. € 160,- while it really is only a € 0,50 component that failed?
Old 05-22-2017, 08:29 PM
  #51
mojorizing
mojorizing's Avatar
I'd say that's the one. I have a spare HVAC harness with sensors, and I got correct ohms as per the spec. info from your link for the 4300K (0 deg C/ 35K ohm and ambient 27 Deg C/ 9.2K )
Old 05-23-2017, 02:52 AM
  #52
ToreB
ToreB's Avatar
The sensor is indeed an 10k NTC, the above mentioned type will be fine.
You could choose a "water drop"-type sensor instead of the disc type. This is smaller and might have a faster temperature response. It could be easier to place into the plastic tube too. Soldering in a new sensor is done in a few minutes.
Cheers,
Tore
Old 05-23-2017, 06:57 AM
  #53
Beezztie
Beezztie's Avatar
Thanks both! I ordered this thermistor and will try to solder it in place, see what it does.
Quick Reply: Oh no, HVAC issues...
