AC Compressor Reseal
My AC compressor has a small leak, enough that the gas has leaked out within a year and as the gas was dyed I can clearly see that it is leaking from the compressor and looks to be coming from between the mating parts of the compressor and the hose connector body grouped under section 3 of the diagram below:
A new AC compressor is around £600 it seems (or £1300 from Porsche!) and the parts grouped under section 3 are around £350 from Porsche alone!
I am planning to remove the AC compressor remove hose connector body, inspect the gasket and ideally replace it if I can find a spare supplier (or make a new one from a gasket sheet and use some blue Hylomar to re-seal it. Hopefully, once re-gassed my AC will be fully functional again. If it leaks, nothing lost, I'll have to replace the compressor.
Does anyone see any problems with this approach??
Is this any good as a replacement unit?
http://www.ebay.co.uk/itm/PORSCHE-91...item5af08e5ada
I'm trying to work out what compressor options there are avaiable for 964 as I have seen at least two different types. We seem to be poibted in the direction of Denso which are expensive.
I had some 'stop leak' applied to mine which lasted a few months but I fear I've now no option to change the evaporator (the only part not replaced) which is the hardest part to get to
That looks to be a good option Zingari. Although still interested to see if Plan A is viable!
I had the front condenser, receiver dryer and an expansion valve (?! - just dug out the invoice) replaced in 2010, which is when it was last re gassed. I thought it was more recent than that! How time flies...
From the diagram it looks as though you could easily deck those surfaces (run them on some sandpaper taped to a sheet of glass). Ensuring that each is flat will go a long way towards ensuring that your home-made gaskets (yes, add hylomar!) can seal.
Sounds like a plan. This is my next job to tackle then...
Ok, so not sure that seal is the only bit that's leaking....
Not sure just revealing that part will be enough, does anyone have any thoughts on whether it is likely to be leaking from anywhere else?!
Generally what we do is disassemble the compressor to see if its worth re-sealing:
1) Inspect the pulley (bearing roll test).
2) Inspect the front clutch hub face for excessive wear.
3) Inspect the coil for cracking and its resistance.
4) Inspect the bores, pistons, and wobble plate and reeds for wear, as well as the shaft for pitting.
If all looks good you can use a Seal Kit
And naturally a new drier, refrigerant oil, evacuate, charge and test (also testing the system to insure the condenser fan is working as well as the pressure switch).
My compressor was going bad several years ago. Instead of rebuilding it which my search revealed hit and miss success, I just bought a NEW one. Only $300 from PelicanParts. And shipping was free too.
Replacement of the compressor was even easier than changing the oil on the 993.
