HELP! 964 not starting...
Symptoms:
Last few weeks, once or twice a week (mainly at night leaving work when cold out), go to start car and get a loud whine/buzz sound when I try to it. It would start after one or two tries.
This evening, when I got in to start car, just made a "spinning" sound, no attempt at ignition, no buzzing sound.
Battery doesn't seem to be the issue - just get a mechanical spinning sound (best I can describe it) - no clicking sounds.
I'm guessing bad starter motor?
Thoughts?
Luckily I was able to borrow a car to get home - but will likely have to have her towed to my indie tonight...
Thanks for any insight!
Thoughts?
Based on your description, I wonder if you have teeth missing on your flywheel? It sounds like your starter motor is running, but not engaging with anything.
Starter prob worn out, and not coming out to grab teeth on flywheel. As common as a ****ty ex wife. I had same deal about a year ago. Go buy a reman Bosch starter for short money and slap her in. Take you about a hr. Easy job.
And the verdict is...
Starter motor - had it replaced and I'm off to the races again! Starter was going from day one. Starts up sooo much better now! opted for a new one with warranty and due to timing (they had one in stock!)
Thanks for the help! Happy motoring.
