axle shaft sealing ring Replacement
Reviving an old post. I am replacing the axle seals and I have found only a couple references to packing the seal with grease. Most posts do not mention it. Is everyone installing with grease and if so, only LiquiMoly PU53 - Porsche Part No #000-043-110-01?
Thanks.
Thanks.
