C4 Major electrical probs
Hey guys! Been away for a long time but I'm back and want to get the 964 in the best shape possible
After 2 years my battery was showing it's age so I got a new one. Plugged it in, drove round the block and was happy. 10 days later I come and the battery is totally dead. So I realised there is some consumer and decided to unplug the trunk light that wasn't working anyway. I tried to jumpstart the battery, but even after almost 10 minutes charging it could only barely crank once slowly.
Since the battery was on warranty I took it back and they charged it up, telling me I probably had a problem with my car's electrical system. I plug the battery in and the dashboard lights up. I hold my breath, turn the key... and... nothing! everything goes black in an instant. Totally dead!
Do you think a major fuse is blown? I am close to getting the recovery truck but I would rather solve the issue on my own if it isn't too serious.
Just a note: my cruise control fuse keeps blowing out, so I'm guessing there is some moderate electrical issues that need attention here
Do you have access to a multi-meter? Can you measure the battery voltage? It should be at 12.5 volts if fully charged. If its less than that, try charging again and measure the voltage. If its not holding a charge then you need another battery. If its holding a charge and the car isn't starting, check your ground straps at the battery and starter. The best way is to remove them, clean them thoroughly and reconnect. Corrosion over time can increase the resistance.
Once you have a good battery connection, your starter should work. If not, you may need to remove the starter to have it tested.
As for the cause of the battery going flat while parked, the process of finding the cause is not difficult, just tedious. You hook up your multi-meter set in DC amps in series with the battery. Be sure that all interior and trunk lights are off. With the key off, start measuring the current draw. A normal 964 should have between 40-60 milliamps of current draw. If yours is higher, then start pulling fuses, one at a time until you find the one that is causing the problem. Then consult the electrical schematics to see what is on that circuit.
About 3 years ago, I had had to go through this process. I had a 500 milliamp draw. The cause was a faulty CCU. It took me about a full Saturday to track down the problem.
Good luck with the repair and let us know if you need anything else.
I had this problem, brand new Bosch battery flat in a week.
I did a little digging and found 2 immobilisers, 1.5 alarm systems and the reminiscence of an 80's mobile phone system!!
Amazing what you can fit in all the nooks and crannys.
Pulled out the obvious and left the immobilisers.
Still runs flat when its left over the winter.
Eventually when I get it re-trimmed I am going to attack the wiring get rid of all the rubbish.
Good luck
Good luck
If you are putting the car in storage, you need to either disconnect the battery or use a battery maintainer. The basic current drain will flatten a battery in a month.
