Is scotland too cold for year round 20w50 in my 964?
Hi ladies, I am about to move from 10w40 to 20w50 (Valvoline VR1), and I know a lot of you guys run this weight of oil. Just checking in, my car gets used occasionally in winter and so temperatures around freezing..are you 20w50 users running through cold winters?
Can't quite believe my 964 and 356 can share the same oil!..
The pour point of vr1 20-50 is -24 c / -11f .
So "20w" will not be of concern until it gets down to -18c / 0f .
https://valvoline.com/pdf/vr1_racing.pdf
On start up at freezing , the oil will be just a bit "thicker" , at running temps the oils will be just about the same same viscosity wise .
Do you know how to graph the weights vs temps ?
http://www.widman.biz/English/Calculators/Graph.html
That far north I'd go for 10w40 maybe even 5w40 as a winter fill. Looking at that graphing tool 20w50 is twice as thick at 0c!
As the saying goes; you want flow not pressure.
Thinner oil is better when the temperature requires it re the oils pour point .
