964 Forum 1989-1994
Suspension question
Old Dec 13, 2013 | 04:50 PM
niche's Avatar
niche
Default Suspension question
Hi guys,
I'm looking to replace the suspension on my 1991 C4. There's a fellow selling shocks and springs that were on his 94 C2. Will they work fine on my car?
Tried looking for the answer, but couldn't get a definitive one.
Thank you!
Javier
Old Dec 13, 2013 | 04:52 PM
FeralComprehension's Avatar
FeralComprehension
Yes; rear mount change was mid 1990.
Old Dec 13, 2013 | 05:13 PM
niche's Avatar
niche
Okay, great! Thanks. So the AWD makes no difference either? I think I'm just confusing the rear mount change... for some reason I thought C4s were different.
Old Dec 14, 2013 | 12:49 AM
FeralComprehension
I thought they were the same but as an example I checked the Tire Rack listings for the KW V3 1990 C2 vs. C4 and there are different part numbers. You'd better look deeper.
Old Dec 14, 2013 | 03:37 AM
niche's Avatar
niche
Will do... thanks!
If anyone knows the answer, please let me know. Gracias!
Old Dec 14, 2013 | 09:13 AM
jimq's Avatar
jimq
Burgled
red old style
white new style
File Type: jpg
File Type: jpg
Old Dec 14, 2013 | 04:18 PM
niche's Avatar
niche
Color coded?! Awesome.
Old Dec 14, 2013 | 05:39 PM
jimq's Avatar
jimq
Burgled
No!
Go by the mounting at the top. They are different.
Old Dec 15, 2013 | 03:30 PM
FeralComprehension
The question now is "Are the C2/C4 rear setups different in some meaningful way."
I didn't think so, but...
Old Dec 15, 2013 | 03:41 PM
nidon's Avatar
nidon
I believe they are the same, i.e c2/c4 the same the difference was early or late
I have a feb 90 C4 and have the latter rear shocks, succesfully fitting bilstiens (same ones listed as c2/c4 at the time)
Old Dec 17, 2013 | 02:41 AM
niche's Avatar
niche
Ok so mine are red. I'm concerned about front and rear. I have a 91 c4 and a fellow is selling his shocks and springs off a 94 c2. Will they fit? I'm more confused now.
Old Dec 17, 2013 | 10:40 AM
FeralComprehension
What I think you should do is look at all of the current suspension vendors and determine if, in general, the C2/C4 rear part numbers are the same or different for a 1992 vehicle. You definitely have the later mounts, so you need a post-change rear setup, the only question remaining is whether the rear setups for a C2 and C4 are different.
Look at the part numbers for the various setups.
Old Dec 17, 2013 | 10:45 AM
niche's Avatar
niche
Good idea. Thanks
