Head Stud Question
Head Stud Question
I just wanted to garner current opinion on head studs for a stock engine. There is a large price difference between standard Porsche steel bolts and alternative 993tt Dilavar, ARP or Supertec items.
Are ARP/Supertec over kill for my daily driver?
Spoke to Engine Builders Supply (EBS) where I bought all my parts from and they suggested to use Porsche steel bolts (around $10 each) rather than the dilavar studs (around $35 each) - when there are 24 to replace it is a big saving.
Engine is now back together and after a spirited drive last Sunday, no oil leaks and no problems. My car is used for reasonably fast driving and occassional track day.
I used ARP studs in my rebuild. I bought my car with it having had a 'rebuild' but it was more of a 're-seal'. They didn't replace the head studs and one snapped after a few thousand miles. I also fitted ARP con rod bolts. It's an insurance policy and the best kind because you pay once and forget about it. I have enough things that keep me awake at night without wondering if I'll need to pay for another premature engine rebuild!
My advice is don't cut corners...
I was intending to get a set of Supertec when I'm in California but speaking to a guy who recently rebuilt a 911T made me question if I was going overboard if i was not modifying the engine.
No problem. I took the 'while I'm in there view' and as well as head stud and rod bolts replaced big ends, had the heads rebuilt with new valve guides and seats, new piston rings, and tons of other bits I can't remember. I don't want to be doing it again any time soon!
