what brake discs are you using?
I think it's time for me to get a set of brake discs for both front and rear.
Currently using cross drilled discs installed from the previous owner when I first bought the car 2 years ago. was running with stock pads and I have upgraded the pads to EBC yellow and they are fantastic.
during light brakes I can feel the steering wheel vibration slightly and I believe it is due to the front discs are slightly warp.
I've been searching online and the only place that I can get cross drilled discs is from design911 and the brand is unknown.
Just wondering what brake discs is everyone using at the moment. and good discs which is not cross drilled? I found EBC disc called themselves performance discs whilst they are not cross drilled...
regards,
Arthur
regards,
Arthur
Using Pagid package set (solid disc), but not recommend.
The surface is uneven when they come out of box. I need skimmed them to prevent steering vibration. They are brand new discs!!
Look like Sebro is better.
regards,
Arthur
regards,
Arthur
The symptom you're reporting is not dissimilar to one I believe mentioned by Boxsey and others before and has, on those occassions, been caused by the change of pad material.
I will probably be corrected, but I'm sure I read somewhere that the pads leave a deposit on the disc, and if this isn't evenly applied (due to existing material build up, etc) a slight vibration can be felt at slow speeds.
If you have a vibration under heavy break pressure then that would point toward the disc being warped, but it could also be down to suspension components being worn!
regards,
Arthur
regards,
Arthur
You're better off buying standard solid discs IMO. Sebro and Zimmerman supply discs to Porsche. You can buy the sebro ones from both Type911 and D911. Don't bother with EBC discs as they're an unknown quantity.
If you want true cross drilled discs you need to fit the 964RS rear discs (at huge expense) and then upgrade your front brakes to 964RS/993 size or go for a big red conversion all round. This gets very expensive.
Go to Pagid yellow or black on new or clean OEM rotors if you like the track, stay with OEM pads on clean/new OEM rotors if you are more "civilized"
I have the 993 turbo brakes on the front and the RS brake discs on the rear - combined with Pagid orange. Breaks like hell, but the noises the Pagids cause is kind of unbearable in public traffic. On the track it's just great, no comparison with the 964 regular brake.
I had this exact conversation this weekend whilst at the MOT place. Guy said Pagid is an OEM, but I am led to believe that the stuff they sell via ECP isn't the same quality. He said Lucas quality is excellent.
Sebro are supposed to be OEM and would probably be the way I went..
Edited to say: Just checked the Girling web site and they are referencing ATE parts so I guess they've been swallowed up.
The old "OEM" grey area again!
UK suppliers use of OEM does vary from the USA version a little
Basically when a UK supplier lists some as OEM, 98% of the time they mean that manufacturer supply parts to Porsche. Pagid supply parts to Porsche (mainly pads) so Pagid discs are listed as OEM
Zimmerman do not supply to Porsche
Sebro do supply to Porsche, only early 1960's solid rear discs and 930 early floating fronts.
99% of Porsche discs are SHW, never heard of them have you?
The cross drilled discs available in the UK from D911 & T911 are Sebro, but as boxsey says, they are mainly there for the looks!
http://www.shw.de/cms/en/business_se...c_brake_discs/
I can't find a mention on their site of supplying Porsche or anything about Porsche on Sebro's site either:
http://www.sebro.eu/company/services.html
However, I suspect that their Porsche contracts are so valuable to them that they're very careful not to say anything that would put them in jeopardy.
