Oil Draining
Hi,
I've just had to replace the elbow pipe from the engine that comes off the rubber hose that comes from the inner drivers arch.
I undid the oil drain plug on the engine - drained it and changed the pipe - some more oil did come from the pipe when I disconnected it which I thought was a bit strange as it's higher than the sump plug.
Anyway I've changed the pipe strained and replaced the oil.
I havent run the car except to move it out the garage.
I've just been browsing the forum and came across this...
https://rennlist.com/forums/964-1989...edure-diy.html
OMG have I damaged my car or will it be ok?
Please advise - I will be taking it for a full service soon also.
Wait...so basically you just drained the sump, plus (I presume...a lot of) oil spilled out of the rubber pipe*...but you just filtered it and put it back into the engine?
I'm thinking that there wouldn't be any harm in what you did...
*which is normal if the oil tank wasn't drained beforehand
