Airbag Fault Codes
Would anybody here have a list of what the airbag fault codes mean for 964.
I've been having issues with mine, cleared it once, came back a week later, then I repaired a blower motor and tore out the old audio and replaced with new. I soldered the clock contacts, and now the faults immediately return.
codes its throwing are: 25, 112, 27, 112
![](http://i228.photobucket.com/albums/ee190/romanoaf/9E9BCAE7-C546-4567-872E-DADAC11110AF-17861-000002126C1538F0.jpg)
Any idea's guys? the only thing I could find were the 996 codes..
Fault 25 Passenger's seat belt tensioner Fault memory/warning light
Fault 27 Ignition circuit, passenger Fault memory/warning light
Has anybody seen 112?
I've got teh same problem. Car came back from the bodyshop with a blown interior light fuse and ABS fault light on the dash suggesting siomething must have shorted when they put it back together. I have replaced the fuse and the lights etc work but I cant fet rid of the fault.
As I do not have a scantool I tried the disconnecting the battery and earthing the +ve lead to discharge the capacitors etc but it still comes on.
Will ToreB scantool give me acces to clear it? Got one of these (on loan to a chum when I had my 993) just need to plug adaptor to access 964.
