wheel help: 11Jx19 et67?
Its going to depend on the look you're going for. To fit the rear that would require a good amount of camber, some smaller tires to give a bit of a stretch (and consequently more clearance), and probably have your arches rolled as well.
The fronts "seem" fine as is.
I'd wait for more wheel experts to chime in though.
with spacers you should be able to get it to work.
1. find my thread on 10ET40 and read about the clearance .. search for 10ET40 in thread title
2. use the calculator to compare 10ET40 to 11ET67 to determine the difference in position of the rim edges
3. then you can understand clearances on the outside & inside
i want good performance, but the car wont see the track. dont want to have to stretch the tires at all.
also dont want to have to roll the fenders. sml, I read through your other thread, and didnt 100% get everything answered. i guess my biggest concern is the 11 fitting between the suspension and the opening. i can use spacers to put the wheel wherever I want, but is 11 too wide on a NB??
what im trying to do is put factory 997 lobsters on the car. I know a lot of people here dont like them, but I have always liked them ever since i first saw the 997. found a picture of them on a 964 and love the look, but it was a wb car.
One thing to keep in mind, Porsche does not recommend the use of 18" rims on the 964, never mind 19". If your car is a boulevard cruiser you should be OK with 19", but if you push it at all, I wouldn't go any bigger than 18", besides you can get all the performance you need from 18" and a better ride to boot.
Just saying.
Just saying.
Just saying.
Just saying.
(a) outside clearance from tyre to fender
(b) inside clearance from tyre to suspension arm
(c) inside clearance from tyre to inside wheel well
i cannot recall if I have read of anyone fitting 11" without fender roll/flare .. but hopefully my thread has details of clearances prior to fender roll.
265 on a 10" has a small stretch type look btw.
