C2 front wheel bearing replacement
Hi guys,
I've got the big nut and bolt out that holds it all together and the hub now feels loose in the upright. I was expecting the ABS gear ring to just fall off once the big bolt was removed which would then allow me to press the hub out from behind. Is this not the case? Seems to be what PET suggests by looking at the schematic?
Rob
Rob
It's ok, the back of the ABS gear has an interference fit into the bearing. A light tap with a drift reaching through the center hole from the hub side and it was off :-)
