Mystery connectors?
Hey guys, I was checking out what I needed to do to swap out my wheel for a Momo on my C2 Turbo, I have already bought the bridge plug and went to check where it plugs into. I opened the panel to find these 3 loose connectors hanging around. now im sure the two white ones should probably be connected and I cant see anywhere the black one is supposed to connect. Does anyone have any idea what these are for???
http://www.flickr.com/photos/nathanjermyn/8513870093/
You'll find connectors like the black one all around the car which are not plugged into anything. The 964 loom is very extensive and ready to plug in to all the options. So where an option is not fitted there will be nothing plugged into an empty plug. I found many such plugs on mine when I did my recent interior strip out.
I don't remember seeing those white ones in my own console so they might be worth investigating.
yeah its the one in the passenger footwell, the airbag bridge plug is still under the metal bracket with the orange seal on it and this one is a male plug, airbag is female, so this is something different. I am not too concerned with the black one as boxsey said its probably for an option not on my car, probably a connector for a C4 or something. The white ones are what I'm interested in. If they are not common in other cars it could be the aftermarket alarm (which has been deactivated).
