Frunk mounted oil tank (ultimate design?)
#31
A piece of art !
Excuse my ignorance but could it not be made flatter, kind of to sit and fit about where the spare wheel was , I imagine it doesn't really matter for you as yours is a race car ....
#32
Hi Kos
Yeh it could be made to what ever shape you want but the flatter and therefore larger it becomes the greater the surge issues! A taller slimmer tank reduces surge problems. Here's a shot of the overall frunk showing the remote filter position.
#34
Well said that man!! I have actually plumbed in the system different to standard for that purpose. The oil return goes through the thermostat/coolers before the oil filter to help this. But the tank has a section for oil aeration, is that the correct spelling?!
#35
Loving that remote filter. I dislike the stock position in the engine bay. I find it impossible to change without dribbling. (the filter, not me)
Would you mind posting a linky to the hose type you're using for this setup?
#36
Ha Ha
I would love to Rob but you know I'm PC inept!!!!
Its Earls Prolite 350 hose quite a lot lighter than Stainless steel braided and no issues with wear/abrasion etc.
I'm using the -12 for my oil cooler set up at present so when I remove everything to change it I'll take some pics, I changed it all when I fitted dual oil coolers.
Simon.
Simon.
#38
My "ultimate 964 frunk" would have:
- 5.5 lb Voltphreaks VPH 750 battery (link to 997GT3 thread)
- Porsche Motorsport GT3 electric power steering
- Oil tank
- Lightweight fuel tank
- 935 Style Chassis Strut Brace (X-style)... if even needed with the 964 shell?
- Rothsport hood prop rod
- Oil tank
Captain says the 964 tank is pretty light and cross bracing wouldn't add much, so all that's left is the GT3 power steering.
With no oil filter and power steering units in the engine bay, and also no AC compressor and with an ITB/GT3 intake... now that would be a great 964 engine bay to look at!
I know you race that beast, so ultimately I hope this mod improves the handling.
Great work, and thanks for sharing!
#39
Cheers
I already run with no power steering so no need for the pump!! I guess you could get a custom made tank to fit in there but on a standard car the brake master cylinder is there so no room.
The tank holds 10 litres when hot, and yes it'll be nice to clean up the engine bay a little more! The only issue is I'll still have the oil filler there!
#40
Evan - what is the 3 cap canister just behind the oil filter. Is this the brake fluid tank for a modified pedal cluster. What pedal cluster did you use and how did you fit it??
Thks
Thks
#44
Hi Gus
Sorry for the late response! The car runs with no abs it was removed when fitting the pedal box, basically it was too intrusive and hampered my ability to brake late into corners!
My car weighs a little over 1000Kg so the lack of brake assist and abs has not been any issue. However in road trim it must be a consideration Re safety!!
All the best to All for Christmas and the New Year!
Simon
Simon
#45
Talk about packaging!
