Oil tank refurb
An update, tank removes fairly smoothly with some wiggling as long as you come back, then down. There is a narrowing of the tank at the bottom front that will clear the thermostat. Otherwise, it didn't feel right to pull it back past the brake caliper and wheel studs.
Also, you unplug the sender from inside the engine bay, remove the grommet from within the wheel arch, and pull the wire plug through. The flexible dipstick tube pulls through with the tank if you are like me and not brave enough to undo it at the tank first. BE SURE TO REMOVE THE DIPSTICK FIRST!!
A photo shoot of my job
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/3067E7E9-3619-4A6B-A7AB-85233A46CD94_zpssi8zxwzb.jpg)
This was too hard to disconnect in place
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/F52DB581-0605-4695-AE84-8AEB30039F6F_zps2bbtojh3.jpg)
So the dipstick tube had to come with the tank
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/BF1E2FAA-5EB9-4D4D-82AA-9C8ACA2DEB6E_zps6rc7zgzf.jpg)
Disconnect the oil level sender
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/0C25C29E-FFAB-4750-8A64-2E2F102B644A_zps1zh8vteg.jpg)
The beast is out
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/236BEAEB-31D9-4E37-8671-90316B821444_zpscovgllnj.jpg)
Cleaning the outside begins
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/41AE4E43-3C5F-47BC-BE89-565EAD689AE7_zpsacpmxobt.jpg)
Sealed off the openings to prevent water getting in
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/2F2EFC86-70B9-41ED-BA7F-8326DEA699CD_zps5uhwccmo.jpg)
Oil sender needs removing first
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/C7AA920D-4156-4131-A109-ADB30C494CC3_zpsaa6oppqm.jpg)
Which required some persuasion before it would let go of the wire
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/5CB0EE10-1708-4EBB-9526-C0290D0577D1_zpse1xpbhud.jpg)
The sender removal
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/A974DF8C-C947-4BC1-A19D-48E22156C3E5_zpsymunlbc0.jpg)
And then some creativity to protect the sender opening, mainly cause I plan to media blast the tank. The green on the top of the studs was to mark the holes location
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/13309127-7361-44C4-9E85-E8218EDF5343_zpst1osfogx.jpg)
Ugh
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/80F75029-95C4-4092-B534-BB6AF84551E3_zpshk2pkncq.jpg)
Fast forward past the glass bead blasting, parts washer-ing, flushing, and ultrasonic cleaning, plus the taping and priming and two coats...
![](http://i849.photobucket.com/albums/ab52/pgordon325/car/97874525-5FFF-4513-8476-0C3C98F0BC4F_zpsexfqxedg.jpg)
Ready for install after my replacement rubber vibration isolator mounts.
Not bad
The beast is out
The sender removal
Ugh
Not bad
I think I found t answer:
https://rennlist.com/forums/964-foru...ml#post7719097
Seems like they are there to help prevent over tightening of the gasket so that it doesn't squish out.
while your at it, its not a bad idea to flush out the oil cooler
you won't believe the gunge that comes out, i used solvent and air pressure until the solvent flowed through clean
Lookin good!
Lookin good!
Did an ultrasonic bath for the tank, but worried that the vibration would loosen the thin cooling fins on the cooler, so I merely used the varsol parts washer and gave it a thorough cleaning. I used a thread sealer and reinstalled the cooler last night and the tank (for me) slipped right back into place. I'm hoping for a picture of the hose layout at the top of the tank, as it doesn't feel right to me yet.
Man that looks great. I've done this same job on motorcycle gas tanks. Was a bit of work, but paid off. I ended up using POR15 on mine. But, stripped the tank with aircraft stripper and used an angle grinder with a wire brush and sand paper. Hope I don't have to do that anytime soon LOL!
Dirt falls into the space and cannot escape. Driving in the rain gets the dirt wet and the dirt holds the moisture against the body and never really dries out. To make matters worse, as the oil tank flexes due to body movement the dirt scours the undercoating off the inner fender. This sets up an accelerated corrosion condition that technically known as entrapment corrosion. Although Porsche does a good job of product engineering, they seem to have missed the boat on possible corrosion conditions like this.
I recommend that everyone remove their oil tanks when working on the oil system to clean the area and inspect the inner fender.
Now would be a good time to overhaul the oil thermostat too. All you need is the viton o-ring for the piston and a cover as you will need to drill a hole in the existing cover (after removing the circlip) and remove it with a slide hammer.
Hi pi5tolpete, great job on the oil tank refurb. Its a nasty gritty job but well worth the effort to do it
I see you've used stainless hose clamps where the screw track is fully perforated. A word of warning about these. Unless perfectly sized ie no part of the screw track contacts the hose, they will cut into the tube and ultimately cause it to fail. I know this from previous projects. The edges of the perforations bite in and chew-up the hoses. It may be better to source some non perferated alternatives. Purely as an example, something like these: http://www.ebay.co.uk/itm/380752885008?_trksid=p2060778.m1438.l2648&var=650159690171&ssPageName=STRK%3AMEBIDX%3AIT
Edited to add - Ah I see you've put some kind of barrier between the hose and clamp to try and mitigate this
