964 Forum 1989-1994
Gear stick gator removeal
Old Jan 13, 2013 | 03:48 AM
robt964's Avatar
robt964
Default Gear stick gator removeal
Hi guys,
I need to remove the centre console but can't see how to detach the gear stick leather gator. How is it detached? I was hoping the gear stick **** and and gator would just pull off once all the centre console fixings were removed but that doesn't appear to be the case.
Rob
Old Jan 13, 2013 | 04:41 AM
freedman's Avatar
freedman
Clipped in on one side
Shown betten than I can explain here
http://p-car.com/diy/handbrake/
Old Jan 13, 2013 | 05:29 AM
911PERVY's Avatar
911PERVY
The gearknob will come off in 15 seconds, no tools needed, no need to touch the centre consul
Old Jan 13, 2013 | 01:18 PM
robt964's Avatar
robt964
Thanks chaps, center console now removed. I still can't see how the gator n **** are removed from the stick?
(I'm stripping all the interior so that it can be recovered)
Old Jan 13, 2013 | 01:35 PM
Sharker's Avatar
Sharker
Pull up.. it is a friction fit
Old Jan 13, 2013 | 01:36 PM
hamah's Avatar
hamah
Pull and wiggle. It's press fit onto a square shape end of the shaft (won't turn). If it is really tight try warming with a hair dryer and/or using a pair of large screwdrivers and two hands to pull up from under the ****.
Old Jan 13, 2013 | 02:08 PM
911PERVY's Avatar
911PERVY
Yes, just a tight fitting rubber ****, gumshield may be a wise purchase!
