Radio Wiring - Advice Request
I removed the buried aerial (from last week's post) and pulled the head unit...and have a few questions before re-assembly. The questions are on this schematic and the accompanying photo shows the wires I'm asking about...thanks for your thoughts. I probably should have worded the fuse question to read "...is meant to protect?"
I have the full electrical manual on pdf.. it is too large to upload, however if you send me your email I can send it to you. the wiring diagram is on page 20.
Just had a quick scan of the diagram and there isn't a yellow wire listed?
So my guess to your questions would be: -
1. The diagram shows a power supply to the antenna booster - so yes pretty sure that would be it.
2. Yes, terminate a new plug, much easier.
3. Could be for a phone system? another amp? alarm?..this isn't on the diagram?
Hope this helps you out?
Good luck
Good luck
Thanks for the thoughts, guys...helped me forge ahead without being overly concerned I might be trashing something incedibly important. As it turned out, the extra fuse was part of the wiring for a no-longer-present CD Changer so it is now gone. A local audio shop couldn't guarantee quality of service from a re-terminated antenna cable...but recommended a very inexpensive marine-use antenna which takes-up very little space and works well. Since the in-window antenna is not used any longer the booster is now discoonected...much cleaner behind the dash. I also found a small power amp which is very nearly the same dimensions as the original Blaupunkt BQA80...so eventually I'll move it from the frunk to under the passenger seat.
