964 Forum 1989-1994
Clutch smell
Old 11-27-2012 | 04:09 PM
Harry Apps's Avatar
Harry Apps
Originally Posted by ray stobbs
I think that the materials used in clutch may have changed in last 10 years
yes now using dead fish instead of asbestos
Ah yes, dried fish are plentiful in China!
Old 11-27-2012 | 04:38 PM
peterC2S's Avatar
peterC2S
Not looking forward to this bit - picking car up this afternoon following a clutch job. Will take clothes peg for nose!
Old 11-27-2012 | 04:51 PM
rollingjack's Avatar
rollingjack
I got new RS clutch about 2 years ago. From 911design, as original.
This summer clutch started slipping and of coarse I got smell too.
I checked flywheel and pressure plate, both was not straight.
You see here cone by pressure plate, it is about 1 mm:
Here are flywheel and pressure plate, yellow inside part has no normal contact:
And both after postprocessing:
Old 11-27-2012 | 05:41 PM
bigunit_271078's Avatar
bigunit_271078
Out of interest would the design 911 clutch be the exact same kit u get from porsche just in original manufacturers box and without the pork markup or inferior relative to Oem product?
Old 11-27-2012 | 06:15 PM
alexjc4's Avatar
alexjc4
my new clutch hasn't made any smells ... yet, maybe I'm not trying hard enough
@bigunit - afaik sachs supplies them to porsche, so as along as design 911 supply the sachs part its as good (or bad) as genuine porsche.
Old 11-28-2012 | 06:04 AM
ZG862's Avatar
ZG862
I wonder if your heater bypass valves may be sticking? If they're stuck open this might provide a quick route from clutch to cabin. Do you get the "clunk" of the valve flaps bouncing when you shut the doors?
