Strange idle issue
Strange idle issue
Well, I think I did something, but can't figure it out.
I was tracking down my injector issues, and took them all out, and replaced them. Put the injectors and fuel rails back on and started the car. Worked like a champ.
Then I put back on the blower, and air filter housing. And replaced the heater hose in the left rear wheel well. When I got back into the car and started it, it went right to 3500 RPM. I can go back and force it back to 1000 RPM with the throttle linkage on the engine, but then it goes back to 3500.
I took it for a drive, and thought that might sort it out, but no luck. Messed with the Cruise Control, but that didn't seem to have any effect.
Anybody have any ideas where to look?
1991 C2 with Tiptronic.
Where does the throttle cable run? Maybe I pulled that while putting in the heat hose.
IHI KING!
Not sure if there is any differences in the routing on a car with a tip. On the manual cars, the throttle cable routes from the butterfly down through the tin at the back of the engine. The cable is then attached to the side of the tranny at the top of the diff side cover. It then goes to a tube in the central tunnel.
Did you remove the intake plenum when you were pulling the injectors?
OK, so I diagnosed and fixed it last night.
The issue was that when I was replacing the heating duct in the right rear wheel well, I must have moved the throttle cable out of the way. When I checked the throttle cable mount back behind the throttle body, the sheath around the cable had come out of the boot that terminates and holds the end of the sheath. So, all I had to do was cut the hell out of my hand getting it back in the space, and realign the throttle cable into its termination. Problem solved, and only required 2 bandaids.
IHI KING!
Glad you got it resolved. I can relate to needing bandaids. My GF always laughs when I work in the garage and come in with cut hands. She give me a hard time about not working if I come in without a cuts. I prefer using superglue instead of bandaids for most cuts.
