Windscreen fluid motor
Guys,
So to get the washers to work I have had to completely seal the pipe going to the Intensive Fluid reservoir. I had checked all the valves and although 2 are no longer working they are now all clear, however water was still being pumped into the intensive reservoir, any idea why?
Now I have sealed the pipe going to the reservoir the washers are fine, all four have good powerful jets of water...
Jack
You have two washer systems supplying common nozzles/jets. Each system is isolated from each other by non-return valves to prevent your problem. It looks much more complicated than it is. You could either clamp the intensive supply hose (as you said) or the other easy option would be to fit another non-return valve (eg from Halfords) in that hose but closer to the reservoir.
Jack
