964 Conversion MSD Ignition
Okay,
So I have the engine in and all ready to fire. I went with a full twin msd box setup and twin coils with the soft rev. Ive been research the proper way to hook up my setup with with a complete bypass of the existing ignition parts as I dont have the original coils or icm's . So I know my dis has a hall sensor style signal. SO my questions are below.
1
o I run the green / purple wire into the dis or use the white wire with the tach adapter to change the signal wave? (read this on pelican) , If so what wire do I use on the dis
2: Can I get the trigger signal from the existing hardness plug that goes to the icms ?
1
