C4 geometrie road/track car
#31
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
True bump steer is always going to be an issue. I'm interested in your drop link solution as opposed to 993RS uprights/ hubs.
#32
I think more caster helps the wheels to self aligne straight quicker
I have 3,5 with no issues,
Some people mention between 4 to 4,5 (max)
Wonder what could be the right balance between front & rear toe & camber to improve the C4 handling,
Or should it just be like the C2 ....!?
Frank are those H&R bars work well ? ...
we all have more or less bump steer issues (toe out) when lowering the cars to RS or more.
The 993 uprights seem to be the most common solution for bump steer. Why is it you dont like that solution?
#33
kos11-12 ... dont waste your time debating caster. with your new wheels, you'll need to go max caster to stop the tyre rubbing on the corner of the guard at the 9 o'clock position (as the max caster will pull the wheel laterally towards the front of the car).
#34
IMHO, there's no difference in caster and camber between a C2 and a C4. You can work on the toe, bars and rake to reduce a C4's tendency to understeer.
Compared to a C2, you'll need a thicker rear bar, some more rake (about 5 mm?) and less front toe (but I wound never go in negative land because you loose grip under hard braking and high speed stalility).
#35
The difference betweem the c2 and c4 is of course we have the addition of equivalent of a VW Golf/Rabbit driving the front wheels. So my instinct is to mix in some Fwd settings. From memory front wheel drive cars will use toe out to improve turn in and reduce understeer. Otherwise same, lots of camber and caster. Without power steering FWD setups tend to dial down the caster so you aren't having to lift the front of the car with your arms.
Those may have a toe In when suspension compress ....?! Maybe that's why they dial some toe out...?! But yes that may work...!
Wonder why I have + 0,12 degrees individual toe at the front.
The 93 RS wheel hub is a buitiful pieces of engineering,
A few peopol reported curing the bump steer issue by raising the front (raising the steering rack) lowering the point where the outer tie rod is bolted has the same effect, but there is a few thing to consider, it will probably work better on a 18 wheel as there is more space between the carrier arm and the edge of the rim, to be able to play with spacers I think using a spherical bearing increases a lot the feel of the steering, I will try to post a drawing of the part I am think making. I imagine the actual 64 outer tie rod with a spherical bearing pressed in ....
#36
Anto,
a bigger bar at the back has also been mention by a few peopol who race the C4...
probably toe , what do you mean for the rack about 5mm ?
#38
Ha yes of course,
that's what I have 5mm lower than RS at the front !
I need to remeasure it all ; it was done a few years ago and have the alignement done again...
actualy thanks to Garreth a rennlister here who race a C4 in US
#40
Anto
by the way I live in Cannes not far from Italy... is there any good track days organised, I think Imola is the closes ...
#41
#43
I think Mugello is #1, and it's also not far from you! (closer than Imola).
Here's a link for you: http://www.promoracing.it/?zona=calendarioauto
#44
Kos,
Yes that's an option as well 50 km difference from Cannes...
#45
Yes, 21 was fitted to the rears of early C2s. My guess is that Porsche reduced it to 20 later to perhaps reduce the potential for oversteer. My '90' has the 21 and I really like the way it feels..a little bit oversteer without being too aggressive.
+1 to the suggestions for max caster (mine's at 4 30 which is close the upper limit). It weights up the steering, reduces the 'light front end feel' and improves stability at speed.
