How to remove crankshaft seal?
1 Attachment(s)
Anybody have any tips on how to remove the crankshaft seal. Pictured below. Its the one behind the crankshaft pulley. Its one of those "while you are in there items" Mine seems a bit stubborn and perhaps someone has some advise on the right way to remove these things.
1. Seal puller. You hook it under the crank seal surface (carefully!) and lever it out.
2. Drill-n-screw. You drill some small holes in the flat surface and thread in some self-tapping screws, then use vice-grips or pliers to pull on the screws. |
Originally Posted by FeralComprehension
(Post 9825741)
Originally Posted by Steve Weiner-Rennsport Systems
(Post 9825928)
Thats the right way to do this to prevent collateral damage.
A suggestion if you use a drill (which i did on my rms recently) is to put a small socket or similar tube over the end of the drill bit and arrange so the drill bit protrudes less than the depth of the seal this allows you to push without damaging whatever is behind the seal when you go through. |
Ricardo,
Either one does the job. Alex, Yessir,..it IS a matter of technique,... :) :) In situations like these, oftentimes one attacks the seal from two different points, 180 degrees apart to pry it out a step at a time. |
Thanks Steve, once I figure this out I will document the proper technique. I should be able to get one of these at my local generic auto parts store.
This tool is a bit diffferent but also could work well I think: |
,I saw those tools, they do look better at giving you a safe angle of attack than the T type regular seal puller.
One thing though, unlike the video, all the seals I've done (5 on the 964 so far) have required huge force to remove, and that design gives less leverage that the old style T puller. As Steve says you want to tease it out in little steps. Edit:This also looks promising, basically a two leg puller with slim hooks, but more expensive http://www.drapertoolbox.co.uk/drape...al-2196-120438 Edit 2: looks like a slide hammer makes the drill and screw technique a bit easier https://www.youtube.com/watch?v=pjCU...e_gdata_player |
The key aspect of this operation is not touching the aluminum sealing surface of the case, nor touching the crank with the tool.
Regardless of which tool you use, that's the "Prime Directive". This is one of those things where experience REALLY helps and if one needs assistance from someone who has that, I would not hesitate to ask. Remember, the consequences of any slight damage will do more than ruin your day. |
1 Attachment(s)
Thank you to everyone. I just removed my crankshaft seal using the following process:
1)Sprayed PB blaster around the perimeter of the seal (let it soak for about an hour when I went to pick up the seal puller) 2)Bought the Lisle 56750 seal puller at my local auto parts store. I carefully use the smaller end as shown below. The smooth part of the tool rests on top of the crankshaft and I simply pried it off. The fulcrum is the right side of the seal. Photo below. It came out very easily with minimal force and no damage to anything. 3)After cleaning all the bearing surfaces, I re-lubed the new seal with a light coat of oil and then tapped it in using a small piece of PVC pipe to tap it back in with even pressure. |
Well done! Definitely one of those situations where the right tool makes all the difference.
Originally Posted by RicardoD
(Post 9826103)
This tool is a bit diffferent but also could work well I think: http://www.youtube.com/watch?v=BtsGU2nLrJg |
I've used the self tapper method many times in the past until several years back I ballsed up a camshaft. I got the seal out just fine, but then noticed the thread of the self tapper had scored the sealing face of the cam - instant scrap :( It was a very narrow seal. I only ever use a lever now.
(Post 9826889)
