Rear anti roll bar C4 '90... Advice!
#47
Hi guys, bringing back this old thread for some feedback ,
I recently fitted a rear H&R adjustable bar, set on hard ,with ERP drop links , (rose joint bearings)
I did not fit the front for now as I have stiffer front springs from the original KW V3 C4 suspensions kit,
The result is , the car is more solid, it doesn't sag on acceleration and on fast corner as before and ifeels more responsive,
Quit happy with the result .
#48
Funny you should bump this... my car was off the road for ~14 mos while I did major maintenance, and now that it's back (and on snow tires) I've been gradually driving harder and harder.
I had the steering rack out so I got this alignment:
Yesterday on the way home I ran this cloverleaf 3x:
Still running no front bar.
The car *rips*. No vicious oversteer, no irritating understeer, just predictable rotation that responds well to throttle input.
I may add a little toe in at the front and take a little more camber out of the rear (which my alignment guy says is contributing to his inability to get closer to zero rear toe).
I'm still happy (very happy) with no front bar.
FWIW.
FWIW.
