964 Forum 1989-1994
2001 996TT 18" wheels on 964?
Old Aug 5, 2012 | 03:42 PM
CS Mende's Avatar
CS Mende
Default 2001 996TT 18" wheels on 964?
Any chance these will fit on my 964?
I suspect they might be a bit wide up front.
Old Aug 5, 2012 | 03:47 PM
Hyper911's Avatar
Hyper911
dont think 11 inch rears in wide body offset would fit at all
Old Aug 5, 2012 | 04:40 PM
Turbohead's Avatar
Turbohead
Fronts yes
Rears
No chance
Old Aug 5, 2012 | 07:06 PM
sml's Avatar
sml
offsets & widths?
Old Aug 5, 2012 | 10:14 PM
ChaseN's Avatar
ChaseN
I tried. I failed.
The rears will stick out an obscene amount. Been there done that. I settled on OEM fronts with 10" et47 replica rears. Fit is darn near perfect.
Old Aug 6, 2012 | 03:10 PM
ChaseN's Avatar
ChaseN
Originally Posted by sml
offsets & widths?
If memory serves:
Front 18x8 et 50
Rear 18x11 et 47
Old Aug 6, 2012 | 08:15 PM
F2 Iceland's Avatar
F2 Iceland
i'm running oem hollow spokes from a tt on my 64
11'' in the back
Old Aug 7, 2012 | 12:29 AM
sml's Avatar
sml
Originally Posted by ChaseN
If memory serves:
Front 18x8 et 50
Rear 18x11 et 47
the front is fine.
the post above answers that 11" can fit ... which seems possible after my 10ET40 fitment ... I still had room on the inside & outside.
Old Aug 7, 2012 | 09:51 AM
ChaseN's Avatar
ChaseN
I guess if the stretched/"stances" look is what youre going for its ok. It definitely is not a traditional looking fit. I've had them physically on my car, and know that it would take more camber than otherwise desirable to make the top of the wheel come under the arch. Plus you have to overstretch a 255 or so tire on an 11" wheel.
Old Aug 7, 2012 | 09:59 AM
ChaseN's Avatar
ChaseN
11'' in the back
Do you have a pic going straight down the side of the car? Kinda tough to see the fitment in a 2D photo taken from the side. Thanks!
Old Aug 7, 2012 | 10:33 AM
sml's Avatar
sml
265 has plenty of room to spare with 10ET40 .. about 10mm on inside and out 15mm to fender on outside (with slightly flared fender).
Old Aug 7, 2012 | 10:48 AM
F2 Iceland's Avatar
F2 Iceland
2.5 degrees camber, 265 tire, running a small spacer making the total offset 37
Old Aug 7, 2012 | 11:49 AM
ruflife's Avatar
ruflife
Would love to see a shot from straight on fom the rear. I would think that ride height would also play a factor. I personally like the Koya 's that were previously on the car
File Type: jpg
Old Aug 7, 2012 | 03:17 PM
F2 Iceland's Avatar
F2 Iceland
Rear
Old Aug 8, 2012 | 02:55 PM
ruflife's Avatar
ruflife
I tried. I failed.
Just a question, you say darn near perfect. - What would you do different? + or - offset wise?
