I need a PC code lesson scantool issue
I am somewhat confused by how PC softeware works, specifically the scantool codes.
What does the .ini file do?
Why is it placed in the windows folder?
What does the .cfg file do?
Why isn't it placed in the windows folder?
The trouble codes file? How does scantool use it, if it does?
Does the scantool executable only look in its folder for info files?
If I move the .exe file out of the folder is that an issue?
thanks
I am an old fortran guy and don't see how this software seeks out data files.
thanks
Steve,
I'm using Win7, and I don't have a scantool.ini file on my harddrive - I thnik that's a legacy file from WinXP and before. I recall that listed the default comport used by scantool.exe. Now, it's controlled by the USB/Serial driver listed in Device Manager.
Scantool gets all the info from scantool.cfg file - this includes handshake address and baudrate to any control unit, error codes and associated description, conversion of temperature from HEX to a meaningful reading, etc.
Look at this post to see how I added the TIP to the scantool.cfg
https://rennlist.com/forums/964-foru...ght=mojorizing
A search of "DougB" will turn up more info - he wrote scantool.
well , my problem is that only some of the functions would work. Motronic would not.
Then if i used the same .exe file from a different folder nothing happened.
just seems strange. i'll play with it this weekend.
Fixed. I had software conflicts.
