Diff and ABS warning lights coming on.
Good idea - I remember threads in the past saying that connector was prone to getting damp / corrosion, but I didn't check it when I had the horn / light issues. Some contact cleaner on that connector and checking the pins for corrosion would be a good initial check.
For Simons benefit - if you face the front of the car, the ABS computer / connector is under the floor carpet on your left if I remember correctly.
