Please take a look at this engine shopping list
With the assistance of my mechanic I developed this shopping list for the renewal of my 964 engine, I didnīt yet include the cylinders and piston set, the clutch and some other parts that we will wait till the engine is open to decide if they need to be ordered, can you please take a look and tell if something is missing? (between brackets the part name in english)
(Parts for Engine rebuild) 30/06/12
1) Cojinetes cigüeņal (Main Bearing Set shell oversize 0,25 mm)
930 101 131 71 (2)
930 101 132 71 (12)
964 101 138 66 (1)
2) Cojinetes de biela (Rod Bearing shell set undersize 0,25 mm)
930 103 147 50 (12)
3) Tornillos de biela ( connecting rod bolt)
964 103 176 00 (12)
4) Juntas del carter (Crankcase Gasket set)
930 100 901 04 (1)
5) Juntas de motor (Engine Head Gasket set)
964 100 902 00 (1)
6) Aros (Piston rings)
964 103 925 00 (6) One per piston
7)Bujías (spark plugs Bosch FR 5 DTC)
999 170 183 90 (12)
8)Cojinetes arbol intermedio (Intermediate Shaft Inner Bearings)
996 101 435 70 (2)
996 101 137 80 (2)
9) Tuercas de tornillo de biela (Connecting Rod Nut)
993 103 174 02 (12)
Thanks for your help!!!!!
930 101 131 71 (2)
930 101 132 71 (12)
964 101 138 66 (1)
930 103 147 50 (12)
964 103 176 00 (12)
930 100 901 04 (1)
964 100 902 00 (1)
999 170 183 90 (12)
996 101 435 70 (2)
996 101 137 80 (2)
993 103 174 02 (12)
I don't know if there is any point in starting a shopping list until the engine is apart.
As far as rod bolts, I would go for aftermarket such as ARP or Raceware, much better than oem.
Just my 2 cents......
Good luck with the rebuild, will be a nice feeling when you get it back.
Why is your shop not doing this? Pointless stating oversize shells etc etc until the engine is apart and things measured and evaluated correctly. You may / may not need valves or springs, camshafts, cylinders and pistons, crankshaft ..... but until you inspect it is impossible to know.
I'd be looking for a std std crank if it comes down to it. Yeah, I am surpirsed there is no upper end stuff.
Agreed you just don't know until you know and the only way to know is pull it apart and check everything.
Sould like a goober shop
cam chains , chain guides
2nd oil filter set up
Power steering pump rebuild kit
Clutch parts
And to everyone else , he is just making a list . He is not ordering parts . When it comes time to order parts he will have done some of the leg work , he will have looked around for prices etc etc etc .
Clutch parts
I would certainly be changing the head studs & would either go for 993TT (fully threaded jobbies) or Supertec etc etc.
You really don't want to rebuild & then have one let go 6 months down the line!!
Regarding upper end stuff, yes it would be ordered later, the main issue living so far from EEUU is that takes 3 weeks to get parts here and I have to pay 100% more for everything than what you pay in the states
Clutch parts
Clutch parts
Actually buying parts from EEUU has gotten rather difficult here, as an example I canīt legally buy U$S dollars no more, even as a senior manager in a big multinational company who pays a lot of taxes I am not allowed to buy foreign currency.( like it happens in Venezuela)
I will have to buy parts with my credit card in small shipments so they donīt realize that I am buying lotīs of stuff in another country
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Thanks ALEX P can you please elaborate on this head studs issue? and where to buy good ones
It would not give me confidence in a shop that would spec under/oversize without having inspected & measured the crank.
As for the delay to get parts, how much time is saved if the incorrect parts are ordered or if additional parts needed.
Not recommending upgraded rod bolts would also cause me to doubt the shop.
If all parts are 2X for import, how much to pull engine and ship to the States for a rebuild. The savings on parts could pay for shipping. And get a known quality builder.
Originally Posted by Gougha
ry;9652840
ry;9652840
Henry if you have to pay so much more, then why not order from the states? Is it an import duty problem?
Also take in consideration that the customs guys will want to be bribed and if not they will make your life difficult by making all kind of excuses why you should not be allowed to get those parts inside the country
Mine is a country where corruption is everywhere especially in the government
If I tried to send my engine overseas for a rebuild, the most probably thing that will happen is it will be stealed somehow in the long bureaucratic process .
And if they donīt steal my engine I will have to bribe a lot of people with good money just to get my engine to the states and back.
Living in the third world is not easy
It might be easier and cheaper to ship your car to the US and back for some event and get a rebuild while here.
But I admit to not comprehending what could be involved with the export/re-import. Maybe the same risks and bribes.
RL Technical Advisor
I do understand shipping and customs issues (I ship worldwide) and its always a challenge in many countries, however its worth spending some time at this.
