Rear spoiler control module Help
Guys A bit of help please
Is the spoiler module under the passenger seat on 90MY/ 964 as it stopped working yesterday
The reason I ask is the passenger seat electric adjustment button stopped working and was feeling around under the seat in the morning to see if the plug had come loose as opposed to taking the seat out and I may of disturbed some thing
The symptoms are as soon as the car his 50 MPH the spoiler warning light comes on so I know the sensor is working OK also the over-ride button does not work
Do guys think I am in the right ball park ?
Also where are the micro switch contacts for the spoiler located in the engine bay if taking the seat out and not finding anything unplugged
I will do some photos for future guidance to others
Token Pic thrown in as we all like pictures
![](http://i120.photobucket.com/albums/o165/clinchy/DSC_0020-1.jpg)
hi the module is definatly under the seat on a 90 car under the dash on 91 onwards the micro switches are under a plastic cover located under the engine lid held on with 2 p/screws i would test your motor first wich is in the same area with a 12v supply disconect the geared cable by pulling the rubber boot off and pulling it out and see if you can wind it up by hand ive had two second hand modules in four years paying around 80 pounds a time retail at 200 new need some one to service them now ?
Found the control module under dash and the micro switches look like new
Thanks chaps I will disconect the gearing as I have a spare 993 motor and try that first
Got to love poking around these cars
Its funny you asked that, I did take the fuse box cover with the list of what number does what and I could not see a fuse number linked with the spoiler If you know it please let me know ,I did find that the seat fuse had blown for the pax seat on a rhd drive car I doubt it is linked ?
When that happened to mine, I discovered that the whole gear mechanism had dropped off. I had no plastic cover at the time and found the gear in the bottom of the engine bay!
Update
So I started with the Fuses and they were fine then I turned my attention to the engine bay
I have a spare 993 engine lid with all the electrics working so I removed the spoiler motor and just plugged it into the live feed on the 964s engine lid and it happily whirred away so that was the fault but on closer inspection of the outer casing on the cable drive to the spoiler mechanism had perished so water could get in and around the inner cable causing it to stick and put extra load on the electric motor and ultimately making it burn out
So guys I would check the outer casing in you spoiler transmission cable or even better remove it an pour a little lube down it![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I will up load some pics later today
RAS you were absolutely right no link with seat, I just am having a unlucky 964 month LOL
I think it is sulking as I used my 993 to go to Le Mans in France They have souls these cars you know
![](http://i120.photobucket.com/albums/o165/clinchy/DSC_0238-1.jpg)
![](http://i120.photobucket.com/albums/o165/clinchy/DSC_0254.jpg)
