Where are the ground strap locations on 90 C4 ?
Does someone have a list of the ground strap locations on 90 C4 ?
Also... the grounds going to pin 30 on the DME plug, does anyone know where they terminate (the actual ground location) ?
Pertinent ground locations in the engine bay?
Thanks !
Thanks !
+1 If anyone knows, i could also use this information for the same make/model year - having likely DME issues with replacement on the way and want to make sure everything around it is also good when I do the swap.
IHI KING!
There are two main ground straps. One at the battery and the other between the starter and the bottom of the car.
As for the grounds to the body in the engine bay, there is a ground for the AC compressor at the compressor. There is also a ground block in the relay panel in the engine compartment.
