964 Forum 1989-1994
M030 Sway Bar? / Track Use
Old 06-25-2012, 06:42 PM
ja78911sc
ja78911sc's Avatar
Default M030 Sway Bar? / Track Use
964 M030 (RSA) is 22mm front and 20mm rear.
I currently have a 1990 and my rear sway bar is 21mm.
Is anyone running the 22mm M030 front and 21mm rear on their 964?
As a reference, the 993 guys like the (993) 22mm M030 front and the (993)Turbo 21mm rear. I have driven a 993 on the track with this set-up and it was very balanced. Just curious if anyone has tried this set-up on a 964?
This is for street/track use combined with Bilstein Sports and H&R springs.
Thanks!
Old 06-27-2012, 01:18 PM
RSAErick
RSAErick's Avatar
Sorry for not posting earlier, but I had forgotten that I've had experience with the 22mm/21mm front/rear combo on a similar suspension setup as yours (mine were H&R coilovers). I was experiencing understeer on the track - mild in higher speed corners, but relatively severe in the slower corners.
I moved to a 19mm 3-way adjustable rear (set at the shortest/stiffest setting), and the handling improved significantly with respect to understeer/oversteer - it generally became neutral, with mild understeer in the slowest corners.
Here is my write-up of the changes, and some discussion of sway bars:
https://rennlist.com/forums/964-foru...djustable.html
https://rennlist.com/forums/964-foru...confusion.html
Anyway, it appears that sway-bar length (in the form of adjustability) is every bit as important as thickness.
Please let us know what your experiences are if you make any changes. Good luck!
Old 06-27-2012, 06:07 PM
ja78911sc
ja78911sc's Avatar
Erick,
Thanks for your response and links to your past threads!
Jim
Quick Reply: M030 Sway Bar? / Track Use
