OBC tach displays 00
Is this car new to you? Do you know if it worked previously?
You can gently slip it out and check the connections. Use soap on the rubber when putting it back in.
Actually, the steering wheel might get in your way, so slide the Speedo out first, then move the tach forward as far as you can, and reach around behind to be sure things are conected.
Which display is showing 00? Have you checked the position of the control stalk? Does it respond to input from the stalk?
Yes, I got it a few weeks ago. I knew it didnt work when I bought the car. The clock also doesn't work when the car isn't running and if fuse 12 is left in, the obc display stays lit.
I feel like it is all tied together. There are some aftermarket wiring for LoJack and a remote radar detector which I plan to remove. All of the functions/lights on the clock work right.
