Instrument Dash Removal or.......
Instrument Trim Removal... or replace the term "Instrument" with "Gauge" or "Trim" with "Cluster".
I have searched all the above combinations but with no success .... so can someone help me out with this.
I want to remove the instrument panel that hosts the clock and gauges - part number 964 552 549 00 - mine is option 8YR on a speedster if it is of any consequence.
![Name: Dash.jpg
Size: 210.5 KB](https://rennlist.com/forums/attachments/964-forum/636090d1338156900-instrument-dash-removal-or-dash.jpg)
It seems like in order to do this the top Dash will need to be removed and the Panel in question should come out - anyone seen any instructions specifically for the Panel that sits behind the steering wheel between the upper and lower dash and houses the instruments?
Any help appreciated as always.
![Name: Dash.jpg
Lifetime Member
Lifetime Member
You were right with 'trim'.
That will just be some black vinyl, I assume. The actual instrument housing is part of the body-in-white. The only way to remove that would be with an angle grinder. :-)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Thanks.
