964 Forum 1989-1994
Horn?
Old May 27, 2012 | 06:56 PM
gazzy's Avatar
gazzy
Default Horn?
Could anyone offer any advice,I've just fitted a Momo steering wheel and appear to have lost the horn (no s******ing at the back).I have connected the two wires from the original connections to the horn push,which I assumed were just to make a circuit but I'm getting nothing.The horn does still work as I have set the alarm off to check,so it's not the horns themselves,any advice gratefully received.
Old May 27, 2012 | 10:14 PM
C24FUN's Avatar
C24FUN
Gazzy,
Couple of things:
At least on my '90 the alarm horn is separate from the pair of trumpet horns that are activated by the steering wheel switch, so checking with the alarm system won't help. FYI, the pair of trumpets and the alarm klaxon are all together in the front right wheel arch.
If the new switch in the Momo is providing a good ground to the chassis, the horns should sound (check with an Ohmeter). Are you sure the horns were working before you did the wheel change? I ask because I was recently surprised when I tried to sound my horn (which I do infrequently) and got no sound at all. Turned out the contacts on the trumpet horns had corroded and no current was getting through. This is a relatively common issue on these 20+ year old cars. I disassembled them and cleaned the contacts and they worked fine.
Hope this helps.
Cheers!
Jim G.
Old May 28, 2012 | 12:20 AM
tbennett017's Avatar
tbennett017
Did you order the correct horn contact part from Porsche? It replaces the other horn contact that gets removed when you remove the stock wheel components.
Search for Mod 7 install or Momo install here and you'll see what I mean.
Old May 28, 2012 | 12:47 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
Here.
Marc
Old May 28, 2012 | 12:57 PM
tbennett017
Thanks Marc.
Old May 28, 2012 | 03:41 PM
gazzy's Avatar
gazzy
Thanks for the replies gentlemen,I'm sure the horn was working prior to my changing the wheel,but as yourself,infrequently used.Anyway you've given me a few things to look at,at least now I've got something to go at.
