Steve Wong chip update?
Hey bros,
I have a Steve Wong chip for cars with cat bypass. Since then I have added a primary bypass to the mix. Is it a big enough change to warrant sending the chip back for one made for cat + cup bypass?
![order](https://rennlist.com/forums/graemlins/order.gif)
Man I think I found the answer on the description for my current chip:
89-94 911 Carrera 2/4 w/premuffler or cat bypass
$375
Engines modified with a cat bypass/premuffler, with or without a primary or secondary muffler bypass. For manual or Tiptronic transmissions, with or without lightweight flywheel. Includes the LWF fix if one is installed.
Duuh, sorry for wasting the threadspace guys
$375
How do you like your Steve Wong chip? Did you have the car before it had this chip? Would you recommend getting one?
I have a Steve Wong chip in my 993 that I purchased to correct a stalling issue. I really like how it changes the car. I've considered one for the 964.
I have a Steve Wong 91 octane, w/o cat and with secondary bypass. I could tell imediately after installing it that it improved my hunting idle as well as low rpm driveablity. The car feels like it pulls harder to redline than before. I can't really compare it to a stock chip because I bought the car with an Autothority chip already installed. I didn't know it was there until I pulled it to install the Steve Wong chip. The guy I bought the car from was an older gentleman that really didn't know much about the car other than it was a 1991 964 and that it was red.
Thanks!
makes the car idle correctly.
watch out for the myth about adaptation via a 'battery disconnect with a spirited drive'. waste of time. you must get a bosch hammer adaptation (or similar electronic tool - sounds like the scan tool thing works correctly).
What about "let the car idle for 5-10 minutes after a spirited drive at normal operating temps"? Is that an adaptation myth as well?
no.
it is all a load of crap.
I spent 1 year trying all the myths ... time which I'll never get back ... finally i did a 5 minute bosch adaptation and the car was amazing at start & idle!
get the bosch hammer (or equivalent aftermarket tool).
