964 Speedo problem
Summer finaly arrived so I take out the 964, model 1993.
Everything work fine exept the speedo did not work. I know that it got is signal from ABS sensor, I think the left front. But I got no ABS warning light. So what could have stop working?
There is a relay looking thing that changes the signal from the ABS sensor to the speedometer. Its in the trunk in the fuse box. I can't remember exactly what number it is bjt you can probably search here and find it. I pulled mine out and cleaned it when I was having speeding problems and it seems to have fixed it. I also cleaned the ABS sensors at the hubs.
http://forums.pelicanparts.com/porsc...bs-sensor.html
That might help you a little. I'm not saying this is your problem but it could be.
You may want to take a look at this link. https://rennlist.com/forums/964-foru...s-working.html. This was my problem a while back.
