Fastener kit? What makes a good selection?
I agree with others that for most things it's best to get Porsche original. Sometimes you will be surprised e.g. the plastic 10 mm nuts only cost pennies. Sometimes you will be astonished e.g. the captive nuts used on the cat heat shields are £6 each!
Saying that I've built up a set of self tappers, J clips, U clips etc which I find very useful to replace the rusty ones:
Steve, what exactly is pictured above and where did you source them? From what everyone has posted it is really just the general self tapping screws/u-clips and trim bracket bolts etc. that can be replaced safely with non-OE items. I would be happy enough to just have those and be able to replace all the tatty/rusted pieces as I work my way through various maintenance jobs.
http://www.ebay.co.uk/itm/10-mil-Acm...item3a713988a0
Middle left to right are assorted spire clips to take various size self tappers. Similar ones are here:
http://www.ebay.co.uk/itm/SPIRE-CLIP...item5642ab3607
Bottom left are assorted black pan head self tappers. These are very useful with spire clips for the wheel arch liners. I got them here:
http://www.ebay.co.uk/itm/Assortment...item43ab2a3ee8
Top left are just M10 nuts and bolts (8.8) that are used for the cat flange.
Nb. While some of these screw/clip combinations can be used to replace existing ones, I don't use them where there is a 'special' Porsche type of fastener e.g. the screws for the fuel pump cover are specific types of screw/bolts.
