964 Forum 1989-1994
Tire wear
Old May 6, 2012 | 12:25 PM
sy308's Avatar
sy308
Default Tire wear
1991 car is lowered. Inside fronts are wearing at twice rate of outside fronts. What factors should I consider for alignment? Does the lowering setup affect the specs of the alignment? Have no issue with handling. P Zero tires. Thanks.
Old May 6, 2012 | 02:05 PM
FeralComprehension's Avatar
FeralComprehension
You have too much camber for your driving style.
Old May 6, 2012 | 05:20 PM
hawk911's Avatar
hawk911
I know I don't over-inflate my tires, but my middle section is almost to nothing, with the outer and inner almost equal--- rear tires here. I'm on RS alignmens specs on Bilstein HD and Turbo springs.
Old May 6, 2012 | 05:57 PM
anto1150's Avatar
anto1150
The 2 possible causes are:
- too much negative camber (as Feral posted)
- toe out (have a look at your a-arm bushes...)
Old May 6, 2012 | 10:11 PM
BGLeduc's Avatar
BGLeduc
I vote toe out. I have run my lowered 964 at -1.5 deg camber on all four corners and really did not see excessive inside tire wear.
On the other hand, I ran a non-Porsche autocross car with a significant amount of front toe out, and it ate the inside edge of my tires very quickly.
Bottom line is a visit to a competent alignment shop is in order.
Brian
Old May 6, 2012 | 11:02 PM
sml's Avatar
sml
buy directional tires NOT assymetric so you can switch them over.
but agree with comments above .... -2 neg camber on front seems to wear well for street driving and occassional track day. search my previous posts for caster and toe-in.
Old May 7, 2012 | 07:52 AM
sy308's Avatar
sy308
Thanks, guys. Basically, an alignment shop is going to have one thing on their mind, "align to spec". This is where I really need your input. After I find out what the car is set to, what do I say??
Old May 7, 2012 | 09:10 AM
sml's Avatar
sml
search my previous posts, where i quoted my specs.
Old May 7, 2012 | 09:12 AM
anto1150's Avatar
anto1150
U say:
- 1,5 camber all 4 wheels
Max caster
+ 0,5 mm front toe
+ 1 mm rear toe
Than you add: "please, don't argue!"
Ciao
Old May 8, 2012 | 07:36 AM
sy308's Avatar
sy308
Thank you for the clarification and extra details. Will follow your advice on this.
