Who Knows??
Who Knows??
I connect the computer to my 964 c4 dealing with the abs problem and know it have tow faults front right speed sensor and the regulating tolerance longitudinal lock code 44 can someone tell me about that one the speed sensor im changing it but i dont know what can be the regulatin tolerance longitudinal lock.
HELP!!!
HELP!!!
Your C4 has a traction control system that uses hydraulic cylinders (locks) to control the differntials in response to how the car is behaving. I've attached a drawing of the lock control circuit. I'd try beelding the locks first. You need a diagnostic unit that has the proper functionality to do it. I also suggest getting the "Prosche 911" enthusiast's Companion" by Streather.
Thanks for answer I was going to start buying the wheel speed sensors but then i start thinking if is the ecu whats damage, if is the selenoide valve whats bad, so i decide to take it to the mechanic
THANKS!
THANKS!
