Turn signal prob
Turn signal prob
Out for a drive last night; signaled for a left turn, made the turn, signal went off automatically when turn complete (as its supposed to). Turned again and now signal light does not go off automatically, I have to turn it off manually. Anyone come across this before? Is there a switch in the steering column that has broken or is it an electrical/fuse issue? Not a big deal, more of an annoyance than anything, just have to remember to turn my signal off after each turn.
OR, the entire turn signal assembly can slide backwards on the steering column. If you look below the wheel, there is an opening below in the housing plastic, where there is a 10MM bolt - can be seen in Marc's thread here at post #11
That can be loose and the signal stalks/switches can be too far back. Check to see if it's tight, or if you can slide the assembly towards the wheel any.
Either that or the turn signal switch has worn out.
