Speedo not working after engine re-install,... need Idea and suggestions
I just re-installed my engine in the car, and the speedo is not working. Am I missing a connector/plug somewhere?
Before anyone ask, the speedo went to North Hollywood Speedo for a full repair last fall and all was working perfect up to when I dissassembled the engine.
Please any help/info would be great.
Thanks in advance.
Thanks in advance.
I also have the ABS and rear spoiler light on in conjunction with the speedo not working. After using the search button, I found a bunch of usefull treads about the speed sensor located on the front left wheel.
I will check the connection this evening as well as the relay/fuse.
Thanks Black930 for the tip.
Stephane
Stephane
This forum is a wonderful wealth of knowledge. I found the problem,..
During my intensive winter upgrade/ maintenance I mistakenly switch the brake wear sensor with the speed sensor on the left side which threw off the speedo, the ABS, and the rear spoiler all at once.
This is actually well documented on this forum.
Thanks to all contributor.
